Testmode 3.01
By mnrivera210 · Sep 14, 2010in Hacks/Mods💬 6 posts👁️ 3,413 views
Posted Sep 14, 2010 · 22:32 UTC#1
I've tried many testmode files and cannot get the unit to boot up under testmode. I tried v2.3 with no luck anyone else have this problem/fix? Thank you in advance.
Posted Sep 15, 2010 · 07:02 UTC#2
here is the one which is working for me
http://rapidshare.com/files/419136856/testmode.zip
maybe you should try a different sd card. some of my older/slower cards won't work for booting into test mode. the newer/faster cards do not show this problem.
Posted Sep 15, 2010 · 18:28 UTC#3
Weird, I've been using the same card with the unit since I received it and it has always worked for me. I followed your suggestion and used a different SD card and viola!, it booted right into testmode. Thank you for your help!
Posted Oct 05, 2010 · 19:01 UTC#4
Hi this link no working.. maybe you can uploaud again pls ? thank you
Posted Oct 20, 2010 · 21:52 UTC#5
yes can someone please upload a new link pleaseee??? :D
Posted Oct 21, 2010 · 02:58 UTC#6
I got mine from the
FX3.1 Link
Yeah you have to download an entire backup, but at least the testmode works.
