Custom POI from SD Card
By mswscco · Sep 16, 2010in General💬 9 posts👁️ 2,405 views
Posted Sep 16, 2010 · 18:16 UTC#1
Does anyone know what folder I should save my KLM files to for custom POIs? I'm creating the files with Avic Feeds on a mac using Parallels, but I have to save the files manually because the card is not automatically recognized. This is for a Z120. Thanks.
Posted Sep 18, 2010 · 08:01 UTC#2
I I used AViC feeds software to open the KML and then used the software's "transfer to SD card" option.
Posted Sep 19, 2010 · 01:52 UTC#3
Thanks. Because I'm using Avic feeds on a mac, I cannot transfer directly to the SD card from the application. I need to save the files to my hard drive then copy them to the SD card. Are you able to see what folder on your card the KLM files are in? For example, favorites are located in:
SD Card -> PC -> POINT -> TONAVI
Posted Sep 19, 2010 · 02:04 UTC#4
If you are using Parallels on a Mac you can indeed save to the SD card. Just make sure the SD card is selected so Windows can see it is inserted as a drive.
Posted Sep 19, 2010 · 05:18 UTC#5
Yes, I can save files to my SD card, but I don't know what folder to put the files in so that the nav unit can see them.
Posted Sep 19, 2010 · 06:08 UTC#6
it should create the proper folders. Just save to the card.
Posted Sep 20, 2010 · 03:11 UTC#7
Sounds like you've gotten it to work. Can you tell me what folders the application created on your card?
Posted Sep 20, 2010 · 03:18 UTC#8
POI and USERICON.
Posted Sep 20, 2010 · 08:51 UTC#9
Okay, finally got it figured out. Need to create folder "NDB" then "CUSTOMPOI" and drop your KLM files in there. Haven't had time to see what happens with custom icons yet.
