Hello All,
I just joined this forum and would like to begin by saying thank you for everyone's hard work.
You have all accomplished so much and it is very impressive.
About my setup- I've had my 910bt for about a year, I was pretty disappointed in the stock image so I'm currently running Abb's latest image (8.25.2010 I believe). -- VERY NICE! I REALLY ENJOY, THANK YOU ABB!
I've searched through the forum and read a lot of the previous posts on F-series/Z-series about tethering via WiFi over an SD card and some unfortunate news regarding the bluetooth adapter not supporting asyncronous data connections however has anyone investigated utilizing the USB connection?
I have an Andoid based phone (evo4g) and have been very interested in trying to tether my Avic-X910BT via the USB connection. I'm using the USB input for the iPod however I'd assume this should work fine as it is just USB after all...
There is an app available for the Droid OS called PdaNet -- it allows for USB or BT tethering to a PC. In addition to being run on the phone. The software requires that a small application installer (about 1.5~2MB) be run on the client PC which wishes to access the internet via USB. The client PC application is available for XP, 7 & Mac OS however not WinCE (not likely that the developer will make a driver for WinCE either..)
When installing the Client Software basically copies over a driver and creates a virtual device which can be used to access the internet via USB connection. You can see the files being installed into your program files directory as it happens. It works very well on my WinXP notebook... I tried installing the APP on my Avic and as I suspected WinCE refused to even attempt to run the package. It's been a while since I've used Windows Mobile however if I remember correctly installers are .CAB files rather than .EXE, correct?
I am a technical person however I am not a software developer. I would like some input from some of the more senior members regarding whether or not the drivers can be ported. If not, is there another solution to activate a network / internet connection over USB?
The client app can be downloaded at: http://www.junefabrics.com/a/desktop.php
Thanks,
mclovin
