X910BT Works With Droid Phones?
By nodeadpixels · Sep 18, 2010in Problems/Troubleshooting💬 21 posts👁️ 10,675 views
Posted Sep 18, 2010 · 20:03 UTC#1
I have an AVIC-X910BT. I currently use an iPhone 3G with it and it works fine - contacts sync, music plays... I've read posts that the Bluetooth works fine with Android-based phones but, I'm curious to know how the Droid OS works with the X910BT to playback music, the voice features for playlists, etc. Does the interface (designed for the iPhone) of the X910BT also work OK with Droid phones? Also, if you could provide known newer Droid phones you have "real" experience with getting to work with the X910BT (particularly for music functionality), that would be helpful. Thanks so much!
Posted Sep 18, 2010 · 22:51 UTC#2
The iPod interface on the unit only works with the Apple iPod devices. If the droid phones support USB audio as a USB drive would then it is assumed in may work. I don't think however I have anyone use them in that manner at this point however.
Posted Sep 19, 2010 · 02:01 UTC#3
Just installed X920BT. I was able to use them on the Handsfree mode and Bluetooth Adudio (Pandora running on droidX)
Posted Sep 19, 2010 · 02:06 UTC#4
Can you plug the phone in to the USB on the unit and have control over the audio files?
Posted Sep 19, 2010 · 02:54 UTC#5
Thanks for the posts so far... When I asked Pioneer they responded it is a case-by-case basis if it would work or not and that I should test the phone first. Problem is, I cannot test a phone without buying one since I don't have any friends that own a Droid phone. I'm still hoping someone can step up and state they've actually plugged one in and it worked or did not work...
Posted Sep 19, 2010 · 06:22 UTC#6
Would test and report in a couple days.
Posted Sep 25, 2010 · 20:09 UTC#7
Bummer - it seems no one has experience using a non-iPhone with the X910BT :-( I'm probably stuck with the iPhone platform, to be safe about it. Not that the iPhone is bad but, I do not want the iPhone 4 until the antenna problem with that phone is fixed. No, I don't consider a bumper a fix. If I'm going to pay $200+ for a phone, it should not have any problems that need to be fixed with a band-aid bumper. They need to replace the antenna unit. I know this might spur some comments about the iPhone 4 ("it works fine," "it doesn't," etc.) but, the post is not really about that. I want to know if there is a good alternative to it for playing music via the X910BT... Choice is always a good thing ;-)
Posted Sep 26, 2010 · 02:35 UTC#8
Well there is no issue with the i4 as long as you have a case, even then its not really an issue for most people. And we're talking about a glass phone here. If you drop it it will break so there really is no one that should have this phone without a case on it. Regardless there will be no fix for this until the fifth gen phone is released.
Posted Sep 29, 2010 · 15:37 UTC#9
Yes, droid works with this unit. I have a motorola droid and it works fine. bluetooth has always worked for phonecalls and I was able to sync contacts into phone. That said, this x910bt DOES NOT support streaming music through bluetooth (A2B2 protocol or whatever). Total pain in the ass as you have to use the audio jack to hard wire in order to stream pandora or whatever. looks like the x920bt now has this. this is my huge complaint with the head unit. I have had droid and headunit for over a year.
Posted Sep 29, 2010 · 16:32 UTC#10
I will be getting a Droid X within the next week or so. I will test to see if the USB will transfer audio control to the unit. I am assuming that if it works it will work like a USB thumb drive or SD card. I doubt it will be similar to ipod fuctionality.
Posted Oct 07, 2010 · 14:26 UTC#11
When i plug my DroidX into the USB port my X910BT nothing happens. The DroidX begins to charge but the navi does not recognize it as a USB device.
On my boss's Z120BT the Droid also begins to charge but the navi says "Cannot use USB memory on this device" or something along those lines. End result is the same - you cant use it - but the Z actually recognizes that something is plugged in.
At one point the Z gave a different warning and actually forced a shutdown of the USB drive and the Droid would not even charge. navi had to be restarted for the USB drive to be reinitiated. This only happened once though.
Posted Oct 07, 2010 · 19:21 UTC#12
Well then that must mean you cant use it as a USB drive on these units then.
Posted Oct 11, 2010 · 14:43 UTC#13
Also, for anyone researching how these phones work with these units - I am able to transfer my phonebook to the X910 and able to do everything that comes along with that. however, the contact name does not appear when a phone call is received. it only shows the phone number even if that phone number/contact is listed in your phonebook. i havent played around with it yet to find a solution but wanted to put that out there.
Posted Oct 18, 2010 · 00:00 UTC#14
Still would very much like to know - I've seen hints, but no absolute "really tested" posts - can the 910 play audio from a Droid device and if so: how does the 910 interface handle music playback (do I have access to all my playlists, artists, genres, shuffle, etc. via the 910's interface); does album art still display, etc. In other words, how much like an iPhone does a Droid phone behave in terms of music playback and what differences are there (maybe Droid has glitches - some devices are not recognized; you can't use the 910's "iPod-like" interface at all or just in part - for example, you can access artists but, not playlists - stuff like that)... Thanks...
Posted Oct 18, 2010 · 00:06 UTC#15
Well I think Newman answered your question. The Droid devices wont work as a USB drive. Headphone out is the only way. Get an iPhone and be done with it.
Edited Oct 18, 2010 by VBLUE42
Posted Oct 20, 2010 · 18:54 UTC#16
So USB only charges the Android phones, thats sucks. Do they make a Aux to USB cable? Gonna be installing my X920BT soon and was wondering how my Galaxy S would respond to it. Wish Pandora link would work without bluetooth
Posted Oct 20, 2010 · 20:24 UTC#17
It doesn't work with BT but this is the best way to use a non-Apple phone with the unit anyway.
Posted Oct 21, 2010 · 00:47 UTC#18
VBLUE42 - you're right, Newman did answer my question. I must have totally missed that post. However, Newman, can you verify what firmware version you are using? Perhaps the latest firmware upgrade resolves compatability issues and would be nice to know if Newman has the latest and greatest. iPhone 4 - antennagate :-( Would love to steer clear of that and my current iPhone is as slow as a turtle so, I'm still holding out hope for a Droid phone or may have to wait for iPhone 5. At the pace Apple puts them out, it'll probably be around March-April...
Posted Oct 29, 2010 · 14:25 UTC#19
I had version 3.0101 when I attempted this. I just upgraded to the newest 3.0102 the other day so I will give it another shot to see if anything changes.
Posted Aug 31, 2013 · 03:47 UTC#20
This is an old post but just a quick update...the avic x910bt WILL stream audio via Bluetooth...BUT...you need to get the free app from the app store.the app converts mono Bluetooth to stereo..theres a few diff apps out there.The reason you need this is because your phone will sync with your 910 for PHONE use only and phones are mono..there is no audio support.But with the app(the one I use is called mono Bluetooth router)the audio will sync thru the phone hardware. I stream I-heart radio and play my mp3's all the time.The only down fall is that you have to adjust the volume thru your phone since the 910 has no audio support. But it sounds great and the app makes it stereo.
Posted Apr 06, 2015 · 01:30 UTC#21
So using the bluetooth mono router app, what input would I set my head unit to in order to receive the signal from my phone and play music?
