Transparent 3D Buildings
By parruso · Sep 21, 2010in Problems/Troubleshooting💬 3 posts👁️ 1,525 views
Posted Sep 21, 2010 · 19:33 UTC#1
Why are some Schemes make 3D buildings from being transparent?
All RealView and similar buildings do not display correctly, but others, such as Red or Blue Pioneer if they do.
You can see the building in 3D, texture, etc, but a bit transparent
Do you know which is the parameter that governs the transparency? Is it a parameter of the Scheme or the Data.zip?
Thank you.
Posted Sep 25, 2010 · 09:02 UTC#2
Somebody?
Posted Sep 26, 2010 · 18:49 UTC#3
It's in the schemes. If you have a scheme that the buildings are rendered to your liking, create a txt file copying the [clip_planes] section from the scheme. Rename the txt file to clip_planes.ini and copy it to your data.zip in the common folder.
You may also search in the mods forum for additional info regarding clip_planes
