Reverse Wire Functionality
By 89MustangGX · Sep 23, 2010in General💬 5 posts👁️ 1,009 views
Posted Sep 23, 2010 · 01:16 UTC#1
Looking through the install info for the X920BT I just purchased, I saw a note that caught my eye. I do not intend to install a reverse camera, but there is a note in the install docs that basically says it is also used to help the GPS tell if you are moving forward or backward and help with positioning. I hadn't planned to connect this wire, but now I'm wondering about it. Portable GPS systems I have used have not had issues with this. Is it a big deal and worth hooking up? Or is it considered overkill by the majority here? Thoughts?
Adam
Posted Sep 23, 2010 · 01:17 UTC#2
it would probably have little effect on GPS, unless you drive in reverse a lot. :mrgreen:
Posted Sep 23, 2010 · 21:47 UTC#3
That was my general feeling on it, but because of what I read in the manual I wasn't sure.
Is this pretty much the general concensus?
Adam
Posted Sep 23, 2010 · 22:59 UTC#4
Yes. I wouldnt worry about it unless you plan to install a camera in the future.
Posted Sep 23, 2010 · 23:49 UTC#5
Excellent, thanks!
