Auxillary Jack on F7010BT
By NDN GQ · Sep 23, 2010in General💬 6 posts👁️ 3,071 views
Posted Sep 23, 2010 · 20:49 UTC#1
Hi Folks,
I have a F7010BT in my car and I tried using the auxillary jack the other day. I plugged in the wire I had into it and the other end into my phone, started the online radio stream but I couldnt figure out how to get it working. Does anyone have any suggestions? I dont have the manual for the unit or I'd have checked in there.
Posted Sep 24, 2010 · 18:58 UTC#2
I have a F700BT. On mine, you need to enable AV2 on the settings screen, then select AV2 as the source to get the aux jack on the front to work. Hope this helps.
Posted Sep 24, 2010 · 20:43 UTC#3
The manual can be downloaded from Pioneer's site and the answer to your question is in the manual. Also, that is a full AV input, not an aux input.
Posted Dec 02, 2010 · 22:14 UTC#4
DOes this require you to buy another proprietory hardware from Pioneer? Like a special AVI jack from them?
Posted Dec 02, 2010 · 23:00 UTC#5
No.
Posted Dec 07, 2010 · 14:57 UTC#6
standard aux cables work fine, however to get video there are cables that are not compatible (different pinouts)
