GPS lost signal when drive....
By kdtty3k · Sep 24, 2010in Problems/Troubleshooting💬 7 posts👁️ 956 views
Posted Sep 24, 2010 · 09:43 UTC#1
i have great signal when just turn on and stay at one place but when i drive it lost all signal.... i called up pinoneer and they said might be a bad antena so i brought a new one still same problem...oh btw i have avic-f900bt fw 2.XX plz help....thnx in advance....
Posted Sep 24, 2010 · 14:20 UTC#2
where is the antenna mounted?
Posted Sep 25, 2010 · 10:12 UTC#3
i tried on top of the roof outside under the hood
Posted Sep 25, 2010 · 13:03 UTC#4
Is your speed sense wire hooked up? Did you do install or was it prof done? Has it ever worked and just stopped working one day?
Posted Sep 26, 2010 · 08:47 UTC#5
i did it myself and no i did not hookup the speed sen. it worked b4 when i had prof done.....instead of of changing the pin to bypass it i just ground the break wire and the pink i put it with the red wire.... i could watch dvd while driving but then gps signal lost after i drive for like 2-3 min....
Posted Sep 26, 2010 · 16:26 UTC#6
WHY
well sending 12v+ to the VSS wire is a bad and dumb ideal, this wire is for the speed sense and is supposed to get a certain signal, not 12v all the time, i cant understand why people think they can can just substitute any part of the bypass instructions for some of their own ideals. either follow the instructions exactly or dont attempt it all all.
a GPS antenna will never work under metal
hopefully you didn't destroy the system by sending 12v to the VSS wire, learn to start following instructions.
Posted Sep 26, 2010 · 16:40 UTC#7
i concur, what was the op trying to do, find a new bypass method?
