Hi everyone. I'm a newbie here. I have an avic-X910BT and first I wanted to update maps (mine were 2008) then I found FX3.1 firmware update and installed it because it already had all updated maps (06.2009). It worked out but every time I turned on my car it asked to choose the language and all brightness and illumination settings were reset so I needed to set them up again. I thought that something was installed bad and decided to get everything back to manufacturer settings. SD card with a firmware from Pioneer web site did its job well and everything went back to normal but maps. Navi couldn't see any maps at that time, though they were in right folder when checking in testmode. Then I decided to install Diaftia-HybridMods V2.3 hoping that it would help. It didn't. My unit still didn't see any maps. Then I decided to go back to Pioneer original firmware again but it didn't work out that time, my unit just didn't see the sd card with firmware. I decided to re-install FX3.1 again but after installation my unit didn't start up just showing splash screen at all the time. I was trying to install it again and again, tried to download it again from the internet thinking that it might be downloaded incorrect firs time, but all without a result. I forgot to tell that the fist time and all the time I tried to update wince I have chosen "format" mode (which was incorrect as I read on another web site but I'm not sure). Someone said that in case if you choose "format" option you need to write an image so I found how to do this ad did it. When restarting my unit in test mode I realized I had the screen reversed so in case I needed to press something on the screen I had to guess where it could be as it was in mirror. After writing the image again result was the same, reversed image in testmode and no booting into normal, DVD/Navi mode. But now instead truing to but and splash screen, the black screen appears after pioneer splash screen and all buttons lights go off. So this is the story. I appreciate any help and hope your experience will help me to fix my Pioneer.
P.S. If there is a way to just return it to manufacturer setting I will be glad if anyone tells me how to do this. Thanks everybody.
