problems with my navigation on D3
By F15098 · Sep 25, 2010in Problems/Troubleshooting💬 5 posts👁️ 1,372 views
Posted Sep 25, 2010 · 22:07 UTC#1
I have a d3 and the navigation was working fine. then i took the radio out for a wile and wen i put it back in the navigation wont let me search for places or for a address. It wont let me fix the clock eather. The only thing it will let me do is go to the addresses i have programed in it. Anybody know what could be wrong? i ordered the new 2010 navi dvd to update it and see if that will fix it.
Posted Sep 25, 2010 · 22:50 UTC#2
Did you connect the P. Brake wire?
Posted Sep 26, 2010 · 16:35 UTC#3
it should be grounded for the bypass. id have to double check.
Posted Sep 26, 2010 · 19:44 UTC#4
Did you complete the bypass as instructed here. The problem you describe sounds bypass related.
Posted Sep 26, 2010 · 22:43 UTC#5
i thought i did but i looked at it and instead of grounding the p. brake wire i had it going to power for some reson. i got it working. Thanks for your help. i dont get how something that simple can make all that not work. Thanks again.
