Z-120BT Install 2007 Hyandai Sante Fe
By kevinortega · Sep 25, 2010in General💬 3 posts👁️ 718 views
Posted Sep 25, 2010 · 23:33 UTC#1
Hello All,
love this forum I have been in snooping around prior to getting my new Z120BT and I got it finally on Friday and going to be doing the install but I have seen some mixed replies in regards to the VSS being hooked up or not.... I have a 2007 Hyandai Sante Fe SE with stock sound so no sub etc.... I wanted to know where the VSS wire is located and if there is anything else I should know... wanting to do the bypass hack also.... thank you all for your time.. and rock on.....
Posted Sep 26, 2010 · 08:19 UTC#2
VSS Wire: UNDER DASH DIAGNOSTIC CONNECTOR POSITION 3
VSS Wire Color: BROWN OR GRAY/ORANGE\
Reverse Light blue + passenger kick, red 20 pin plug, pin 2
Parking Brake green or gray/orange - parking brake switch or BCM, 26 pin plug, pin 23
Posted Sep 26, 2010 · 16:24 UTC#3
thank you....
