how to: load new maps on f700bt
By momo422001 · Sep 27, 2010in Hacks/Mods💬 3 posts👁️ 1,310 views
Posted Sep 27, 2010 · 07:36 UTC#1
hi i have avic f700bt, which i recently updated to 3.0 from 2.06. i found new 2010ta maps for northamerica and downloaded them, what i did was i deleted the maps and poi in igo folder of the myflash disc on sd card and replaced them with new one and after that i went in test mode and copied the new maps to the unit, but after booting the maps still show 2008-10 only... i did research in all the topics even tried putting fx3.1 after which the unit didnt even start so i reverted back to 3.0, which works fine but still the old maps, any help will be greatly appreciated..
thanks
Posted Sep 27, 2010 · 16:41 UTC#2
The maps are found in 'MyFlashDisk/APL2/iGO/Content/map'. If you replaced all the maps in that folder as well as the POIs, then it should work. If it does not, then you have installed the wrong map files.
Posted Sep 28, 2010 · 03:39 UTC#3
ya thats where i installed the new maps, but nothing worked, instead my 700 wont even start up. i checked new files were .fbl anyways i had to reload the 3.0 firmware and then it again works fine now, with 200810 ta maps..
