rear camera on switch install
By stroked x · Sep 28, 2010in Problems/Troubleshooting💬 7 posts👁️ 1,375 views
Posted Sep 28, 2010 · 19:53 UTC#1
i just installed my rear view camera, and i think i did something wrong :( lol
i put a lighted 3 prong switch on my dash so i can switch the camera on anytime not just when im in reverse. but every time i switch the camera on i blow the fuse for the radio under the dash. here is how i wired the camera
on the back of the switch:
ground: to metal ground behind dash
acc: to acc from back of deck (tap in)
power: to camera at back of vehicle.
the camera is grounded in the back and the purple wire at the back of the head unit is tapped in the power lead on back of my switch.
what did i do wrong?
Posted Sep 28, 2010 · 20:05 UTC#2
You are probably grounding the 12V ACC from your deck which will blow the fuse right away.
You need a SPDT (3 contacts) switch as follows: The common contact should be the parking brake wire on your deck; another contact should have 12V coming from your reverse lamp, the last contact should have 12V ACC.
Posted Sep 28, 2010 · 20:17 UTC#3
if i have 12v coming from reverse lamp then i wont be able to turn my camera on anytime. just when in reverse. i want to be able to turn the camera on anytime. and i do have a 3 contact switch.
Posted Sep 28, 2010 · 20:26 UTC#4
U may have a wrong switch for what u want. Get the right one.
I'm assuming u have the rear cam wired correctly, ground and 12V ignition.
The way I explained it should work like u want. In one toggle state, it should operate normally. In the other, it should bring up the rear cam view.
Posted Sep 28, 2010 · 21:45 UTC#5
What unit do you have? You should not need a switch for your purpose. The unit allows you to view rear view as well as reverse if you have the camera wired correctly.
Posted Sep 28, 2010 · 23:05 UTC#6
i have the avic-d3
Posted Sep 28, 2010 · 23:08 UTC#7
No switch is needed to get rear view.
