Honday Odyssey 2007 EXL (no res/nav)
By bootay · Dec 27, 2006in Vehicle Specific Wiring💬 3 posts👁️ 1,708 views
Posted Dec 27, 2006 · 17:39 UTC#1
Looking for VSS and Reverse wires for AVIC-Z1 install
Mark
Posted Dec 27, 2006 · 18:26 UTC#2
pioneer will tell you NOT to hook it up and to tuck it in the kick panel. it provides about 3 feet of accuracy and a couple features you probably wont use anyways.
Posted Jan 04, 2007 · 01:09 UTC#3
2007 Honda Odyssey
Speed Sense blue/white PCM, conn. A, pin 29
Notes: The PCM (Powertrain Control Module) is on the passenger side fender.
Reverse Light green + dr kick or MICU, 14 pin plug, pin 11
Notes: The MICU (Multiplex Integrated Control Unit) is part of the driver side fuse/relay box. It has two plugs on the side edge of the fuse/relay box.
merry xmas
