Posting a link would be helpful. I'm also curious as to what type of camera I'd need for an AVIC F90BT as I've seen them for NTSC or PAL...which do we/I need?
If you are in North America you need NTSC compatibility.
This is the link to the camera I bought. When it rains you can see the drops on the case, not a big deal but one with some kind of weather shield might be nice, if it doesn't interfere with light to the camera and look too big. Mine is attached to the license plate I drilled a 1/2" hole to run the cables in and filled it with silicon. The hole is not visible.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0559423811
i ran the ACC ignition line, reverse line and camera in line from the stereo to the trunk. Connect the ACC to the + power on the camera. Ground the - power on the camera and connect the video cable. This config will allow you to use the camera at any time the ignition is on by activating it with the stereo.
To have the stereo auto switch to the camera when in reverse (so cool) connect the reverse line from stereo to the + line of your reverse tail lamp.
of course wrap all the lines you put in with electric tape, at a minimum where the connections are.
If all the connections are good it should work fine.
