Camera Troubles with 110BT and X5
By christy123 · Oct 03, 2010in Problems/Troubleshooting💬 4 posts👁️ 806 views
Posted Oct 03, 2010 · 00:51 UTC#1
had z110bt installed today on my truck . i had 90bt installed previously. reverse camera never worked properly. i was told the reverse camera didnt work with that model that well. so this was one of the main reasons i upgraded.
camera doesnt work when in reverse with the settings...camera on and polarity- battery.
when i change polarity to ground , all i see the the camera all the time.
I went back to the installer. he said it is the vehicle issue and suggested creating a relay.
any suggestions?
thanks
Posted Oct 03, 2010 · 02:21 UTC#2
Your installer is full of crap. Take it back and tell them to get it right or refund your install charges so you can go somewhere else. Backup cams are very easy to install and they work will all units.
Posted Oct 03, 2010 · 03:55 UTC#3
the only problem is that this installer just replaced the the radio . the wiring was done by previous installer who installed 90 bt.
Posted Oct 03, 2010 · 04:52 UTC#4
Regardless, camera problems have nothing to do with the head unit or the vehicle. It is strictly install related. Any installer worth his weight should be able to install a backup camera with his eyes closed.
