Widescreen vs 4:3
By BenBrown · Oct 08, 2010in Problems/Troubleshooting💬 5 posts👁️ 965 views
Posted Oct 08, 2010 · 01:45 UTC#1
Is there a fix for this scenario? I insert a standard 4:3(full screen) DVD into the Z110BT, which has been updated with the new software and map updates, and it always stretches the picture to fill the screen where the picture is not supposed to be widescreen(16:9). There should be black on either side allowing the picture to be viewed normally like any other DVD player. In the DVD settings I have the "TV aspect ratio" set to 16:9. I have tried all three settings and still stretches the picture.
Posted Oct 08, 2010 · 03:20 UTC#2
Either turn of the widescreen or try the 4:3
Posted Oct 08, 2010 · 04:32 UTC#3
Where is this setting or are you talking about the DVD settings?
Posted Oct 08, 2010 · 13:28 UTC#4
Lifted from the User's Manual - always a good place to start.
Changing the wide screen mode
- Touch [Wide Mode] on the “AV System Settings” menu.
Each touch of [Wide Mode] changes the setting
as follows:
- Full (full)
A 4:3 picture is enlarged in the horizontal direction only, enabling you to enjoy a 4:3
TV picture (normal picture) without any omissions.
- Cinema (cinema)
A picture is enlarged by the same proportion as Full or Zoom in the horizontal direction
and by an intermediate proportion between Full and Zoom in the vertical direction;
ideal for a cinema-sized picture (wide screen picture) where captions lie outside the frame.
- Zoom (zoom)
A 4:3 picture is enlarged in the same proportion both vertically and horizontally;
ideal for a cinema-sized picture (wide screen picture).
- Normal (normal)
A 4:3 picture is displayed normally, giving you no sense of disparity since its proportions
are the same as that of the normal picture.
Different settings can be stored for each video source.
The same setting is automatically applied for the following grouping.
DVD-V, DVD-VR, DivX
EXT1 and EXT2
AV1 and AV2
iPod
When video is viewed in a wide screen mode that does not match its original aspect
ratio, it may look strange.
The navigation map and the rear view camera picture is always viewed at Full.
Posted Oct 09, 2010 · 03:51 UTC#5
Yes I did find it myself after posting the question. Thanks for the info
