either answer the damn questions or shut the hell up... ...the whole point is to put it in our selves.
if we are to believe that you are capable of installing, then you should be able to convey whats going on better than you did. if you cant figure out that when wires are too short, that you need to extend them, then you instantly get thrown into the know nothing, harness hacking, duct tape and T-tap using, car fire starting rookie that you are
VBlue is just a straight shooter
quoted for truth
the point is to help your fellow man.
that is only if the fellow man is capable of doing the work, i know i surely wouldn't give out information to someone that might not be capable of following directions and cause some serious damage
what the hell do yall care if I did blow it up.
a great installer, would never give instructions to somebody that would damage their car, it would look bad for that installer even if the instruction where incorrectly followed. and thats just bad business. then your just going to be back, asking how to fix more stuff that you messed up on, causing us to spend more time helping the unhelpable
So either HELP people on here, or shut the FUCK UP!
well first off, we've helped more people on this site alone than you have in any, so maybe you should shut the phuk up, also, only a moron would think that talking to a mod that way would ever end in a good way (for you at least, for the rest of us, we have one less immature jabronie to spoon feed everything to)
so enjoy your ride on the banwagon
