So I've just installed a VTL300c Boyo cam to my z120 and now when the engine is running the display has horizontal lines running up and down the display. When the engine is off the display is clear / when the engine is running the lines start and seem to get faster when the RPMs go up.... like it's in sync with the tachometer. I did a search and came up with a possibility of the rear cam RCA plug may be too close to a 12v power wire and another that talks about grounding the RCA ground shield: viewtopic.php?f=6&t=10847&p=72060&hilit=camera+static#p72060
Any thoughts on this would be greatly appreciated as I'm a little shy of trying the grounding the RCA option. Maybe the cam is just crap. I've read of other people having trouble with interference with HID lights..... hmmmmm I just don't know.
Thanks in advance
