F900BT is blocked in it's splash pic
By mad23 · Oct 19, 2010in Problems/Troubleshooting💬 6 posts👁️ 1,132 views
Posted Oct 19, 2010 · 17:35 UTC#1
Hi, today i was updating my F900Bt EU to 3.0 firmware, i have followed the manual point by point but it didnt work'ed, i tried to restore the original "My Flash Disk" from my backup and it still doing nothing, it boots and freezees in the splash pic.
Any idea?
Posted Oct 19, 2010 · 20:54 UTC#2
Ok, now it passes through the splash pic and then all lights turn off and the screen goes black, nothing else happens.
Posted Oct 20, 2010 · 20:37 UTC#3
Was this the update found here or the one from direct from pioneer? can you still get into testmode via the SD card? If you can still get into testmode, you should be in good shape to fix it.
Posted Oct 20, 2010 · 21:24 UTC#4
It's ok now, i updated the firmware to the 3.02 version, installed the new files for igo8.3 and it booted with out any problem, it seems to be a problem with the DATA.zip file and the firmware version.
Posted Oct 21, 2010 · 02:29 UTC#5
good to know! B)
Posted Oct 23, 2010 · 21:14 UTC#6
Hi i was having a similar problem. I was trying to upgrade and flash my f700bt to the x3.01 version thats on this site. I followed the instruction. After finishing the install, i did a restart, and instead of seeing a black screen after the "now loading" screen, the now loading screen now loops over and over. I reverted back to the original and tried to reinstall it again. I can still get to the test mode screen. I'm just lost on what to do now.
