AVIC Z2 speed sensor problem and gyro?
By noss88 · Oct 21, 2010in Problems/Troubleshooting💬 2 posts👁️ 1,257 views
Posted Oct 21, 2010 · 00:55 UTC#1
Hey guys, so I had this z2 for about 3 months. I bought it used from ebay and been using it since then on my 2005 WRX. I recently installed the alpine pdx 4.100 amplifier and everything worked fine for about 2 weeks. Then i realized some reason people weren't hearing me when I talking to them through the microphone so I checked to see if the plug was loose. It was not loose, so I turned the system on and tried to call someone to see if it worked or not. Not only did it not work, I did not hear my friend talking through my car speakers. I did the complete factory reset and still nothing. Not only did the microphone not work, the GPS guidance doesn't guide me anymore, it says my speed pule is NOK, I can't use those virtual gauges (the acceleration, speedometer, etc) I went to check the hardware connection status and it says something about the gyro not working? The only thing that works is the Radio.
In short, nothing works except the radio.
any ideas?
Posted Oct 21, 2010 · 02:19 UTC#2
Sounds like the unit went bad. Not much you can do except discuss it with the eBay seller.
