Upgrading my Z1 system w/CNDV-1000HD upgrade discs. After 2 hrs. of loading updated map database, the final "Update Screen" will not allow me to restart unit ("OK" button remains inactive). Tried manual reboot (per call center) with no change. Any thoughts? Thanks in advance.
CNDV-1000HD Upgrade for Z1
CNDV-1000HD is for european units only (HD1/HD2/HD3) and not compatible with the USA Z-type models....
Not correct...
CNDV-1000HD is the same part number for USA and European models. I have a USA copy setting on my desk...
See these links.
http://pioneerelectronics.com/PUSA/Car/Accessories/Map-Upgrades/CNDV-1000HD
Not correct...
See these links.
OK. my mistake. but are you sure the European and USA versions are really the same, despite having the same name ?...
As it's also a firmware update, I expect there to be differences....
They have the same part number, but the discs are different. Depending on what county you order it will determine which version is sent to you...
hi,
i've search for this : CHange wallpaper, but found nothing ...
i' currently upgrading my AVIC HD3-II and i wondered how can i change the boot up screen/wallpaper ?
i just have to put my wallpaper in the USER directory, then change it in the menu ??
what resolution ? jpg ? png ?
thank you
