Custom Backgrounds
By cmparramore · Oct 23, 2010in Hacks/Mods💬 2 posts👁️ 3,107 views
Posted Oct 23, 2010 · 13:30 UTC#1
I was wanting to find out if you can upload custom backgrounds to the X920BT and if so what is the procedure?
Posted Oct 25, 2010 · 18:46 UTC#2
You cant upload a custom background but you can upload a custom start up slash screen. To change your start up slash screen See below.
From Page 164 in your manual.
Changing to the splash screen
stored in the SD memory card
You can change the splash screen that ap- pears when the navigation system starts. Copy your chosen image to the SD memory card, and select the image to import. p Splash screen images should be used with-
in the following formats; — BMP or JPEG files — Allowable horizontal and vertical size
are 2 592 pixels x 1 944 pixels or smaller — Allowable data size is 6 MB or smaller
p Proper compatibility with allowable files is not guaranteed.
p Importedoriginalimageswillbestoredin the built-in memory, but the ability to save these images cannot be guaranteed com- pletely. If your original image data is de- leted, insert the SD memory card again and re-import the original image.
p Themaximumnumberofimages,includ- ing the images in the built-in memory, that can be imported and displayed on the list is 200.
1 Create a folder named “Pictures†on the top-most directory of the SD memory card and store the picture files in this folder.
2 Store the picture files in the “Pictures†folder.
3 Insert an SD memory card into the SD card slot.
= Fordetailsoftheoperation,refertoInsert- ing and ejecting an SD memory card on page 15.
4 Display the “System Settings†screen. = Fordetails,refertoDisplayingthe“System
Settings†screen on page 161. 5 Touch [splash Screen].
The “Select Splash Screen†screen appears. En
6 Touch [select from SD]. The “Select Splash Screen†screen appears.
7 Touch the image to use as the splash screen from the list. The image is displayed on the screen.
8 Touch [OK].
The image is set as the splash screen, and the “System Settings†screen returns.
p ImagesimportedfromtheSDmemorycard are added to the list on “Select Splash Screenâ€.
