Hello:
I am on day 2 since putting everything back together on my install of a new Z120BT, PAC SW-ips, PAC backup camera, Sirius SCC1 and Scosche FDSR in a 2010 Ford Explorer Sport Trac with existing factory Sub.
I lOVE everything about the system! Backup camera, NAV guidance, Sirius etc etc.
However, I took a 2 hour drive today and the unit will 'power-down' for no apparent reason and will then promptly reboot itself going to the Splash screen and then re-establishing bluetooth etc. What would cause this? It seems to do it about every 15-20 minutes, almost on cue. When unit reboots it does resume playing same source and will also resume the NAV guidance if it was active pre-shutddown.
Could this really be a power connection problem? I did the install myyself, made very good crimped/sealed connections and everything was grounded. I also did the 'famous' mute wire bypass.
Thanks for any clues? Should I contact Pioneer? The unit IS under warranty.
Regards, B3
