USB and iPod input
By DeEePiDDy · Oct 30, 2010in General💬 7 posts👁️ 1,391 views
Posted Oct 30, 2010 · 06:54 UTC#1
Is there a way to have BOTH a USB input available as well as have the iPod cable hooked up? I see the Kenwoods have both available simultaneously.. can the x920bt do it as well?
Posted Oct 31, 2010 · 01:09 UTC#2
No.
Posted Nov 03, 2010 · 20:45 UTC#3
I was going to try and put a 4 port powered USB dock in the Ipod hookup to see if I could plug in the Ipod and have extra ports for a ext hard drive or my Android phone but decided not to. I was told it would work though
Edited Nov 03, 2010 by Jefe21
Posted Nov 03, 2010 · 22:38 UTC#4
every body else that has tried it has said that it wont work, the avics dont have the drivers for a USB hub.
Posted Nov 04, 2010 · 01:10 UTC#5
It half ass works to the point that it will be more aggravating then useful. There is also opinion that it could damage the USB function of the unit.
Edited Nov 04, 2010 by VBLUE42
Posted Nov 04, 2010 · 14:36 UTC#6
That's what I thought too.
Posted Nov 04, 2010 · 15:00 UTC#7
by the way, this is why the USB portion of the ipod cable is so short, so that you can un plug it when you want to and be able to plug in a flash drive so that you can use the same input as both options at the same time, or instead of using a USB flash drive, just use a SD card, thats what most of us do
