2004 SportsTrac Install
By BoneKTiki · Oct 30, 2010in General💬 4 posts👁️ 969 views
Posted Oct 30, 2010 · 14:05 UTC#1
I want to the AVIC-X920BT in my 2004 Sportstrac. Some are saying that it will not fit. I have the standard 2 DIN radio with the factory subwoofer. When I read the demensions of the X920 Unit versus my opening it seems like it will fit. Any help would be great.
Thanks,
John
Posted Nov 02, 2010 · 15:24 UTC#2
a DD unit will fit in any 01-05 sport trac, you will need a dash kit, one compatible model is the scosche FD1330B
you will also need a wire harness, make sure you get the right model for a factory subwoffer like the metra 70-5519, you will also need a resistor to go inline with the remote amp turn on wire to keep the factory sub from "popping" every time the radio is turned on and off, a 1500 ohm resistor should work fine
Posted Nov 02, 2010 · 23:31 UTC#3
Thanks for your help. It is much appreciated.
Posted Nov 03, 2010 · 03:36 UTC#4
no problem and good luck
