Is there anyway I can tilt the screen? I went through most option on the unit and read the manual.
Thanks, Dave
Thanks, Dave
Thanks, Dave
Not very well. Page 14. Press the Eject button.
Is it a permanent fix or just when you need to eject a disc?
I don't use that feature. I gave you the page number for a reason. If you had looked you would see:
"The adjusted angle of the LCD panel will bememorized and the LCD panel will automatically
return to that angle the next time the
LCD panel is opened or closed."
