Dead F700bt
By pablopsd · Nov 01, 2010in Problems/Troubleshooting💬 6 posts👁️ 1,755 views
Posted Nov 01, 2010 · 21:17 UTC#1
Hey All,
Well it appears that my 700 is dead. It was working fine, then I lost my contacts today. Next time in the truck it would give me the splash screen , then shut down. I restarted the truck and that did not help. I also did the reset button to no avail. Lastly I tried to update to the latest firmware that I could download, v 2.008. I only had 2.006 in it. That will not reboot and load either. I called Pioneer, and they tell me that the software is corrupt and that the firmware update will not correct it. $200 for repair, plus i have to remove it and ship it in. Any thoughts? Is Pioneer tech correct? This unit has never been modified with any hacks. 100% stock, other than firmware updates. Now I need to decide what to do with it. I know many of you guys are always messing around with the system on this thing, so maybe there are other things I can try. Thanks
Pablo
Posted Nov 02, 2010 · 12:54 UTC#2
Try the FX3.1 update. You have nothing to lose.
Posted Nov 02, 2010 · 20:30 UTC#3
I have never played with test mode and stuff. I am understanding this, if I use test mode, does the radio boot from the SD card? I then use the linked update and it reflashes the OS in the unit? That is what Pioneer wants to do for $200. I am correct in understanding this?
Posted Nov 03, 2010 · 15:38 UTC#4
Correct the f700bt will boot from the SD card, it will update the OS and it will update your AVIC software.
Posted Nov 04, 2010 · 03:24 UTC#5
Success!!!! Thanks for the suggestion. It took a lot of work, and a crash course in torrents and RAR archives etc, and the Windows environment. Also I tried a few times, but could not get it to boot into test mode. I finally tried a smaller SD card and that did the trick, or so it seems. I had a lot of difficulty in the Windows environment formatting my 8 gig SDHC card. When it gave me problems in the F700, i was questioning weather the fact that I formatted it with Disk Utility as fat32 in the MAC environment was the issue. It shouldn't be but you never know. Anyway, I have music again and Nav!
Posted Nov 05, 2010 · 18:09 UTC#6
Great job!Glad it worked out! 8)
