Speaker Question
By louiea · Nov 04, 2010in General💬 3 posts👁️ 1,042 views
Posted Nov 04, 2010 · 14:08 UTC#1
Can I use a 2ohms speaker with a F90BT or do I need to stick with a 4ohms speaker?
Posted Nov 05, 2010 · 01:44 UTC#2
4 ohm for front and rear only. 2 ohm permissible on the sub channel.
Posted Nov 10, 2010 · 15:52 UTC#3
if you try to run a two ohm speaker off of every channel, it will damage the unit. you need to go with 4 ohm or higher to be safe, if you want to drive 2 ohm speakers you will need to get a high current amp (almost all four channel amps should have no problem driving a 2 ohm speaker)
just for shits and giggles, where did you come across a 2 ohm speaker(non subwoofer? is it from a factory bose system or other premium sound system?
