Z120BT (upgraded from 110) Freezing
By bfschroe · Nov 07, 2010in Problems/Troubleshooting💬 4 posts👁️ 752 views
Posted Nov 07, 2010 · 19:42 UTC#1
I have a Z110BT that has been firmware upgraded to the 120bt software (latest update 2.003). It has been intermittently not responding to any touchscreen presses. Can't even press "OK" on the nav startup. Restarting the car usually (but not always) fixes it.
Does this sound like hardware or software problem?
Should I try to reupdate firmware?
Bruce
Posted Nov 07, 2010 · 19:52 UTC#2
Sounds like a screen issue.
Posted Dec 31, 2010 · 16:53 UTC#3
Some new info on this. Happening more frequently now. When starting car have no sound and no touchscreen response. Only hard button that wold is mode. After about 10 minutes everything starts to work properly. Hard to believe it is really a hardware issue (screen works perfectly when working at all).
Are any known software issues with the firmware upgrades (was a 110 but upgraded to 120 software with all updates applied (003 rev)
Bruce
Posted Dec 31, 2010 · 17:59 UTC#4
Regardless at this point your unit is defective. Have it swapped or exchanged.
