Color changing LED
By gcsd3742 · Nov 12, 2010in General💬 3 posts👁️ 3,693 views
Posted Nov 12, 2010 · 14:08 UTC#1
i'd like to be able to choose the color I want not it randomly keep flashing? is there a way to stop this?
Posted Nov 12, 2010 · 22:04 UTC#2
I do not have U310 so I am not sure of the exact steps but there is a way to do it. It is done from the main settings menu. I forget exactly how you access it but I believe you turn off the radio source then hold down a particular button. From there you use the knob to scroll down to the LED/illumination settings.
take a quick look at your manual and you should find out how to access the settings menu. from there it is pretty self explanatory.
Posted Nov 12, 2010 · 22:10 UTC#3
Page 104:
-Press SRC/OFF and hold until the audio source turns off.
-Press the center of MULTI-CONTROL and hold until the initial setting screen appears in the display.
-Turn MULTI-CONTROL to select “RGB Illuminationâ€.
-Press MULTI-CONTROL left or right to select the desired color.
