My Flash Disk\User\UserData deleted, touchscreen no longer working
By kruuth · Nov 12, 2010in Problems/Troubleshooting💬 8 posts👁️ 1,092 views
Posted Nov 12, 2010 · 17:40 UTC#1
Deleted this for Abb's mod, then the touchscreen ceased to function. Put it back, and the system is forgetting the voice for navigation and the illumination won't stay set. Ideas?
Posted Nov 13, 2010 · 02:31 UTC#2
by deleting you mean you trashed all of the abb's mod files? most likely that wont work. Hopefully you did a backup before the mod, restore your original backup
Posted Nov 13, 2010 · 03:53 UTC#3
It is not the \My Flash Disk\User\UserData to delete. It should be \My Flash Disk\User\UserData\iGo!
Restore the backup in TestMode!
Posted Nov 13, 2010 · 13:38 UTC#4
Yes, it is the 'Igo' folder in the user data that has to be deleted. Let me know if you can get it back up again, if not, PM me and I will send the original UserData file as I have a backup and this should bring it back up
Posted Nov 13, 2010 · 15:11 UTC#5
No, I smartly just renamed the folder and added the .old extension to it. This all happened when I restored the original name. Issues:
Won't remember the voice for nav.
Won't remember illumination color.
It does remember the last song I was playing off the usb, and my memory radio stations.
Posted Nov 17, 2010 · 17:45 UTC#6
Anything?
Posted Nov 17, 2010 · 18:10 UTC#7
Anything?
The first thing that I would do is to try and reload all the files back in again. Make sure that ALL the files are put in replacing the old. If that doesn't work, reinstall the firmware and then reinstall my mod and delete the igo folder in the user data. That should fix it.
Posted Nov 20, 2010 · 05:50 UTC#8
I replaced the folder with the original one....it worked for about 10 mins and suddenly while driving the unit rebooted and now I'm back to the same situation.
