Avic Z1 Upgrade
By Norman56 · Nov 12, 2010in Problems/Troubleshooting💬 3 posts👁️ 1,347 views
Posted Nov 12, 2010 · 19:03 UTC#1
Hello this is my first post here. I purchased the CNDV-900HD upgrade disk from Pioneer. In the instructions it mentions that you need to update your firmware to install this map upgrade. The Unit in my car has the following details Version, 01.0000, Device Number, E1693651E186851
CDDB VERSION, 06-01-0010.
Do I need to find the firmware update to have the CNDV-900HD install to work?
In the instructions it says you need HDD Application Version 2.140000 or higher for it to work. Is this true?
Thank You
Norman
Posted Nov 12, 2010 · 20:13 UTC#2
You need to follow the instructions to successfully update the maps. Why are you installing CNDV-900HD (2009) instead of the newer CNDV-1000HD (2010)?
â– Press the “MENU†key
â– Select the “Settings†tab
â– Select “Hardwareâ€
â– Select “Service Info Screenâ€
â– Press & hold left upper corner of the “Hardware Version†screen for a few seconds to see the TRUE version number.
See this site for firmware update details and download:
http://www.pioneerelectronics.com/PUSA/Support/Navigation/AVIC-Z1+and+Z2+Firmware+Update+Download
Posted Nov 12, 2010 · 22:17 UTC#3
Thanks Garret,
I see there is a cndv 1000 now. I got the 900 a while ago and am just getting around to installing. I got it going in the right direction now thank you
