SYS.TXT Settings For IGO8
By 69sixpackbee · Nov 12, 2010in Completed Mods/Themes💬 1 posts👁️ 15,749 views
Posted Nov 12, 2010 · 23:56 UTC#1
I think I saw this here a long time ago but maybe you modders or "would be" modders might find these useful if they are applicable.
Enjoy,
Bud
[2d]
[3d]
[3d_config]
[bluetooth]
[config]
[debug]
[defaults]
[device]
[feature]
[folders]
[gps]
[kml]
[loading]
[local]
[map]
[msnd]
[mydata]
[mydata.tracks]
[navigation]
[other]
[phone]
[poi]
[power]
[rawdisplay]
[route]
[screen]
[settings]
[smartzoom]
[speedcam]
[sound]
[timezone]
[tmc]
[tripcomputer]
[tts]
[usb]
[warning]
[2d]
guidancearrow_disappearlevel=600
guidancearrow_maxshift=12
minguidancearrowsize=20
minguidancearrowsize_zoomlevel=1200
maxguidancearrowsize=65
maxguidancearrowsize_zoomlevel=0
[3d]
3d_tmc_road_extra_width=200 ;
building_camera_distance_far=500
building_camera_distance_medium=50
building_camera_distance_near=10
disable_3d_labels=0 ;
fade_distance_for_car=50
fade_distance_for_guidance_arrow=500
guidancearrow_contour ;
guidancearrow_first_size=1.1 ; scale of 1st arrow
guidancearrow_first_alpha=24 ; transp of 1st arrow
guidancearrow_second_size=0.8
guidancearrow_second_alpha=12
guidancearrow_skew ;
guidancearrow_thickness ;
guidancearrow_width ;
guidancearrow_zoomfactor ;
max_poly_distance_lower
max_poly_distance_upper
max_poly_segments_shown
max_track_distance_lower
max_track_distance_upper
max_track_segments_shown
min_poly_distance
min_poly_segments_shown
min_track_distance
min_track_screen_ratio
min_track_segments_shown
road_clip_plane_camera_delta=50 ;
road_clip_plane_to_camera_height= ;
show_guidance_strip=1
show_guidance_arrows=1
track_screen_ratio
use_all_building_textures=0 ; not?
[3d_config]
disable_roadsign_navigation_mode=1
roadsign_lines_per_screen=12
rotated_roadsigns=1
[bluetooth]
send_showphoneui_on_dial=1
[config]
autoset2donmap=1
autoset3doncockpit=1
hideroadaltname=1
overspeedrewarnbelow=1
SafeModeMinSpeed=40
[debug]
autosave=1
bringtotop_afterresume=1
buildneworderlist=1
cache=2048
compass_type=2
disable_3d=0 ;disables 3d buildings and roads
disable_outlookpoi=1
double_pixel_mode=2 ;3d mode fastdraw
doublepixel_stable_frame_time=500 ;time in ms before leavin fastdraw
earth=1
enable_buildings=1
enable_landmark_occlusion=1
enable_roadshadow=1
enable_roadsign=1
fov=40
gnome_dem_files=1
hide_itiner_crossing=1
join_dual=0
lang_registry_2006=1loop_sim=1
loop_sim=1
max_memory=
mute_os_key=1 ; a value of 1 mutes the click noise from the OS when touching a touchscreen
no_file_cache="0"
nortc=1 ; RTC = real time clock aka the devices internal clock
pin_sets_start=1
poi_labels=1
replay_tmc=1
reserve_memory
run_on_mio_mantas=1
screen_calibration=1
show_arrows_on_route=1 ; little arrows in direction of route
show_device_type=0
show_gps_pos=1 ; this works again ;O)
show_lane_info=1
show_ltn=1
show_multinode_maneuvers=1
show_oneway_3d=1 ; 3d arrows in one way streets
show_oneway=1 ; show one way on or off
show_pedestrian=1
show_performance=0 ; cpu / mem / whatever bars on top of screen
show_plural=1
show_poi_areas=1
show_poi_boundingrects=1
show_priority_maneuvers=1
show_prohibited_maneuvers=0
show_rawdisplay_info=0 ; handy for seeing what igo chooses as display driver
show_residentonly=0
show_speed_limit=1
show_turn_penalty=1
show_signpost=1
sim_speed_factor_max=8.0
skip_eula=1 ;skips the End User License Agreement at start-up (only happens on first run anyways)
slowsim=1
smart_2d=1
sound_q_length=200
speedcam_enabled=1
split_dual=0
strap_waypoints=1
supress_highway_enter=0
supress_straight=0
supress_trivial_left=0
supress_trivial_right=0
tmc_all_stations=1 topmost=1
traincrossing=1
tts_expected_engine_delay=1400
tts_getaway_time=200
tts_min_ready_wav=1
[defaults]
mainroadness=60
shortessness=50
simplificationness=40
[device]
type="MIOC210" ; force device type
typeid=3 ;In Igo8.exe: MIO device detected, use KernelIOControl method
[feature]
text_guidance=1
signpost_coloring=1
tmc_event_coloring=1
tmc_traffic_side=1
[folders]
app="%SDCARD%/iGO8" ; change this if applicable
sdcardpath="\Storage Card"
exe=""
data="\Storage Card\igo" ;custom,save
content="\Storage Card\igo\CONTENT"
textures="custom"
models="custom"
secondary_root="IPAQ\NAV"
[gps]
background_navigation=1
logging=0 ; see also mydata.tracks
port=2
baud=38400
source="nmea"
disable_advanced=0
default_longitude=2.294760 ;starting postion on the map before GPS is found.
angleoffset=
autotilt=0
autotilt_minzoom3d=40
autotilt_maxzoom3d=1000
autoscroll_on_click=1
default_poi_icon="Contacts" ;
defaulttilt3d=75000
defaultzoom2d=1000
defaultzoom3d=500
disable_3dstick_labels=1 ;
drive_carefully=0
empty_favorites=1
exit_on_restart=0
laneinfo_signpost_enabled=1
mapfontscale=130 ; for 2d and 3d map
maxzoom2d=60000 ; zoom out level (disabled get you into space ;O)
minzoom2D=40 ; zoom in level 2d
minzoomglobe=100000
msgbox_max_width=50
newalignment=1 ;
poi_show_all_btn=1
popup_info=1
resolution_dir="320_240" ; tells what resolution to use in a multires skin
screen_snap_distance=40
showselection=1
show_exit=1 ; obvious
show_gps_config=1
show_minimize=1
show_orientation=1
show_timezoneslider=1 ;
show_tmc_config=1
show_zoombar=1 ; also see zoomscale_disappearing
shutdown_time=0
skin="ui_igo8"
spec_fav_count=4
theme="skin\igo8_plus.zip"
use_big_lang_flag=1
use_spec_fav=1
waypoint_list_ignore_autosource=1
vga=1
Zoom2dpercent=
show_only_ahead_of_car=1
[kml]
default_icon=1
[loading]
loading_bmp="loading.jpg"
progressbar_bmp="loading_progressbar.bmp"
progressbar_x=85
progressbar_y=134
show_progressbar=0
show_statustext=1
supress_straight=0
text_align=1 ;Left=0,Center=1,Right=2 and Justify=3
text_fontcolor=xFFFFFF
text_fontsize=30
text_w=600
text_x=100
text_y=400
traincrossing=1
[local]
; Date Format: To select your desired format, delete the ; infront of the format you want and ; in front of the rest (or just delete all of the other lines)
; Dateformat = 0; YYYY-MM-DD
; Dateformat = 1; AAAA.MM.GG
; Dateformat = 2; YYYY / MM / DD (DEFAULT)
; Dateformat = 3; YYYY-MM-DD
; Dateformat = 4; AAAA.GG.MM
; Dateformat = 5; YYYY / MM / DD
; Dateformat = 6; DD-MM-YYYY
; Dateformat = 7; DD.MM.YYYY
; Dateformat = 8; DD / MM / YYYY
; Dateformat = 9; MM-DD-YYYY
; Dateformat = 10; MM.GG.AAAA
; Dateformat = 11; MM / DD / YYYY
[map]
2dheadup=1
3d_brunnel_shutdown=
3d_buildings=1
3d_buildings_distance=2
3dcarsizemin=5000
3dcarsizemax=10000
3dcarsizemul=30000
3d_dem=1
3d_dem_detail=2
3d_landmarks=1
3d_max_tiltlevel=7500
3d_max_zfar=500
3d_max_zoomlevel=2000
3d_min_zoomlevel=40
3d_roads=1
3d_scale_carmodel=1
3d_tunnels=1
alternative_roadnames=0
auto_nightmode=0 ; see also nightmode
cross_border_routes=1
follow_gps=1
inertia_on_map_move=1 ; sets autoscroll on the map, tends to be buggy though sometimes doesn't stop.
map_mode="3D"
maxFovRatioForPoly=8
maxPolyDistances0 = 2000
maxPolyDistances1 = 3000
maxPolyDistances2 = 4000
maxPolyDistances3 = 5000
maxTrackDistances0 = 2500
maxTrackDistances1 = 3500
maxTrackDistances2 = 4500
maxTrackDistances3 = 5500
minPolyDistances0 = 500
minPolyDistances1 = 500
minPolyDistances2 = 500
minPolyDistances3 = 500
minTrackDistances0 = 500
minTrackDistances1 = 500
minTrackDistances2 = 500
minTrackDistances3 = 500
roadblockicon_maxzoom=2000
rotation="0"
shields=1
show_labels=1 ;
show_oneway=1 ; turns on or off the arrows showing one way streets
stop_rotate_on_map_move=1
terrain_in_2d=0
textured_poly=1
viewpreset_front1="30,100,7200,10"
viewpreset_front2="140,7000,6000,10"
viewpreset_front3="140,7000,6000,10"
viewpreset_top="600,50000,225,10"
zoomscale_disappearing=1 ; works with show_zoombar
KukurikU
11th April 2009, 01:35 PM
and some more:
[msnd]
; How does msdn work? Movies, Weather, Petrol prices, etc.....
msnd.start=0
[mydata]
favicon=""
max_favorites=16
max_histories=40
num_favicons=7
[mydata.tracks]
auto_track_visible=1
record_auto_track=0
tracklog_folder=""
[navigation]
autoreplan_action="AUTO"
gps_pos_to_road=1
show_countrychange=1
show_current_city=1
sim_speed_factor=1.0 ;Determines how fast the simulation runs, 1=realtime
skip_grab_viewchanging=1
[other]
demo_mode=1
[phone]
driver="TAPI"
exe_path="\Windows\cprog.exe"
win_name="Phone"
[poi]
enable_pois_before_080217=1 ;080217 is the date can be changed as needed
multipoi=1 ;allows you to use more than one set of POIs at a time (will show duplicates though)
[power]
backlight_day=100
backlight_night=54
backlight_slow_api=1
backlight_sync_with_OS=1
battery_warning_limit=10
powermgm_state=0
power_off_mode=1
power_off_timeout=300
skip_resume_process=1
skip_suspend_process=1
[rawdisplay]
class="landscape" ; adjusts the orientation, other options are rlandscape, portrait, square,wide
driver=GX ;GDI or GX
highres=0
screen_x=320
screen_y=240
stretch=0
[route]
allow_carpool=0
allow_charge=1
allow_ferry=1
allow_highway=1
allow_special=0
allow_unpaved=0
allow_uturn=1
correctness=80 ; we used to have a slider for that
fast_car_multiplactor
fast_car_speed
motorcycle_multiplactor
motorcycle_speed
planned_route_weight=7
route_type="ECO"
scenic_highway_weight=4
scenic_scenic_weight=2
slow_car_multiplactor
slow_car_speed
tmc_weight=6
vehicle_type="truck"
[screen]
current_background="default.bmp"
focus=1
focus_activator_key
focus_color
focus_followlinks
focus_halign
focus_sprite
focus_type=2
focus_valign
focus_list_keydown
focus_list_keyleft
focus_list_keyright
focus_list_keyup
focus_list_move_before_scroll
menu_animation=0
nightmode=0
[settings]
accident_map=1
accident_panel=1
accident_recalc=0
closed_map=1
closed_panel=1
closed_recalc=0
closures_map=1
closures_panel=1
closures_recalc=0
congestion_map=1
congestion_panel=1
congestion_recalc=0
danger_map=1
danger_panel=1
danger_recalc=0
heavy_map=1
heavy_panel=1
heavy_recalc=0
invalid_map=1
invalid_panel=1
invalid_recalc=0
police_map=1
police_panel=1
police_recalc=0
roadworks_map=1
roadworks_panel=1
roadworks_recalc=0
weather_recalc=0
weather_map=1
weather_panel=1
[smartzoom]
autozoom_address=100
autozoom_coord=200
autozoom_cos=200
auto_follow_on=1
auto_follow_time=10
auto_smartzoom_time=8
default_visibility_altitude=4000
enabled=1
enabled2d=1
maxangle=85
maxzoom=250
minangle=8
minzoom=60
overview=0
overview_distance=20000
overview_zoomlevel=10000
restore_smartzoom_on=1
use2d=1 ;use2d is to use separate smartzoom for 2d and 3d. Once this is implemented in a UI it should be set to 1.
zoom_after_find=1
[speedcam]
disable="_SUI", "_GER", "_AUT"
enable_at_startup=1
speedcam_sound="!alert1"
usemio=-12,90,37,27
[sound]
auto_mute=0
ding=0
device_bps=
device_samplerate=
device_stereo=
dynamic_volume_maxspeed=100
dynamic_volume_minspeed=40
dynamic_volume_os_volume_max=255
dynamic_volume_type=1
dynamic_volume_voicemaxspeed=80
dynamic_volume_voice_volume_max=100
incomingcallsetting=0
queue_length=200
sound_volume=255
sound_muted=0
suspend_time=5 ;timeout for wavedev to goto sleep
use_os_volume=1
voice_muted=0
voice_volume=255
[timezone]
auto_index=29
default_timezone=29 ; GMT+1 amsterdam
index=29
manual_dst=0
reset_os_timezone=0
sync_os_timezone=0
sync_time=1
use_auto=1
[tmc]
auto_detour_calc=0
;announce_total_route=1
baud=38400
ignore_all_events=0
port="COM,1"
source="gns"
;harman eten galik opentmc2 opentmc1 hyundai samsung amaryllo royaltek gns
[tripcomputer]
num_of_trips=4 ; default igo8 has only 3
[tts]
always_say_road_names=1
announce_exit_directions=1
announce_street_name=1
priority="HIGH"
skip_exit_numbers=0
tts_buffer=131072
tts_logics=3
[usb]
disable_on_startup=0
enable_on_shutdown=1
quitmap_msg_quits=0
[warning]
approach_beep_distances=200
approach_beep_sound="!sectionbeepB"
max_section_time=240
overspeed_sound= "!alert3" ; speedcam sound
pedestrian_warning=0
pedestrian_warning_threshold=10
section_beep_distance=200
section_beep_sound= "!sectionbeepA"
section_end_sound= "!sectionend"
section_start_sound="!sectionstartA"
speedcam_maxdistance_from_road=
speedcam_max_angle=20
speedcam_max_lookahead=400
speedcam_snap_distance=200
speedcam_soundtype=1
speedcam_visualtype=1
speedcam_warning=1
speedlimit_warning=1
speedlimit_warning_visual=1
speedlimit_warning_voice=1
speedwarn_alt_builtup_based=1
speedwarn_alt_limit
speedwarn_alt_tolerance
speedwarn_tolerance=110
speedwarn_alt_toltype
speedwarn_toltype
warn_distances=130:450,110:350,90:300,60:200,40:10 0 ;These numbers are apparently in the format of Speed:Distance.
Edited Jan 28, 2015 by JasonH
AVIC411.com Static Forum Archive · Preserving 42,334 community discussions and 300,445 posts for historical & technical reference.
