No Ipod Sound F700BT
By edelator · Nov 13, 2010in Problems/Troubleshooting💬 5 posts👁️ 1,058 views
Posted Nov 13, 2010 · 18:46 UTC#1
I recently had my vehicle battery replaced and since then my iPod sound does not work. My iPod connects, the artwork shows up and it looks like it is playing a song with the status, but there is no sound. I get sound from CD / Radio fine, just not iPod. This all worked previously. I've tried my iPhone and no sound from that either. I can't see any fuse that would have blown. Any ideas?
Posted Nov 13, 2010 · 22:21 UTC#2
did you set AV1 to "ipod"? as this is not the default, it would need to be reset after the battery was replaced
Posted Nov 14, 2010 · 02:33 UTC#3
What ipod cable are you using?
Posted Nov 14, 2010 · 16:54 UTC#4
i dont think that its a wrong cable issue(since it has worked in the past), but that's not to say that it isn't a faulty cable issue (although it does seem weird that the cable would go bad at the same time that the battery was replaced)
Posted Nov 14, 2010 · 23:58 UTC#5
Setting AV1 to iPod is it! Thanks so much. I don't remember setting that when I installed the unit but I must have.
Edited Nov 14, 2010 by edelator
