IPOD Touch/F-90BT Help
By Khmersta · Nov 15, 2010in Problems/Troubleshooting💬 3 posts👁️ 793 views
Posted Nov 15, 2010 · 07:58 UTC#1
I recently updated the firmware on my iPOD Touch (2nd Gen) & when I used it to connect to my F-90BT it no longer plays any songs. I can still select the iPOD & see the track listings on the AVIC but when I go to play a song or video, nothing. It just says "STOP" where the album art should be. Has anyone experienced this after the update?
Posted Nov 23, 2010 · 21:52 UTC#2
Same over here...
Not any solution found.... :'(
Posted Nov 24, 2010 · 23:57 UTC#3
Are you plugging the ipod directly into the USB cable out of the back of the unit and ONLY the USB cable? if so you need to add the CD-IU230V cable. the F serries avics need this cable and you to select av1 as "iPod" I had this same problem and this fixed it! Hope it helps. I also have an Ipod touch 2nd Gen.
