No sound
By helpdat_1 · Nov 16, 2010in General💬 2 posts👁️ 1,018 views
Posted Nov 16, 2010 · 23:24 UTC#1
Please help,
I just installed an AVIC-F90BT into a 2005 4Runner using a harness of type 70-8113 Turbowire that consist of the following wires:
COLOR: GRAY - RIGHT FRONT
WHITE - LEFT FRONT
PURPLE - RIGHT REAR
GREEN - LEFT REAR
BLACK - GROUND
YELLOW - BATTERY/MEMORY
RED - IGNITION/ACCY
BLUE - POWER ANTENNA
BLUE/WHITE - AMPLIFIER TURN ON
Everything seem to be operating fine except there is no sound.
Posted Nov 18, 2010 · 17:36 UTC#2
well if you are using the 8113 then you have a premium sound system, you do have the blue/white wire from the avic harness connected to the blue wire on the metra harness right(amp turn on from the AVIC is blue/white but for some reason its blue on the toyota harness)
if so test and make sure that there is 12v+ coming off of that wire when the radio is turned on
there may be a problem with the RCA outputs on the avic, if you look in the dash cavity with the radio removed, there should be another set of harnesses, you should be able to unplug them and instead of using the 70-8113 harness, a 70-1761 harness should plug into there, this will bypass the factory toyota amp and use the pioneer amp instead
