X920BT; mute from external source?
By Gregscalade · Nov 18, 2010in General💬 15 posts👁️ 1,724 views
Posted Nov 18, 2010 · 17:32 UTC#1
I just got my X920BT and will be installing it this weekend. I plan to mod it such that the DVD, nav menu etc are accessbile during driving.
My question is how do I (or even, can I) wire the unit such that it is muted when an external device goes off and the ground wire / circuit on the device is closed? Can I tie that wire into the X920BT such that it mutes?
Thanks for the help
Posted Nov 18, 2010 · 18:21 UTC#2
I guess that my question, stated more clearly is as follows: If I install a pin & wire next to the yellow wire (over one spot) to accomodate the GPS/DVD enabling at all times, can I still use the stock yellow wire to connect to an external device such that X920BT mutes when the circuit is closed to ground?
Posted Nov 18, 2010 · 20:42 UTC#3
Just insert a new wire instead of pulling/moving the mute wire.
Posted Nov 19, 2010 · 00:25 UTC#4
What exactly are you trying to do?
Posted Nov 19, 2010 · 00:52 UTC#5
I have an external device, similar to a radar detector, that has ground wire/circuit that switches when it alarms. I would like to hook the device to the pioneer, such that when it alarms the stereo mutes. I assume that I can do this with the yellow wire?
However, I don't want to lose the ability to use/play DVD/gps at all speeds.
So can I use the stock yellow wire as described above and install a wire next to it to achieve gps/DVD capabilities at the same time?
Posted Nov 19, 2010 · 01:13 UTC#6
You will need to use the mute wire for the "other device" purpose and use a different wire for the bypass. Are you going to be using any amplifiers?
Posted Nov 19, 2010 · 01:25 UTC#7
Yes, two amps.
Posted Nov 19, 2010 · 02:03 UTC#8
Tap the amps remote into the 12 volt switched wire and use the remote wire from the unit as your bypass wire.
Posted Nov 19, 2010 · 02:55 UTC#9
I don't follow.
Rem turn on for amps should come from blue & white wire from head unit. The remote wire from my detector should connect to yellow wire, and I should install a new wire next to yellow and connect to ground?
Posted Nov 19, 2010 · 02:57 UTC#10
What I wrote will work as I described.
Posted Nov 19, 2010 · 03:05 UTC#11
Ok...but I don't follow what you wrote?
Posted Nov 19, 2010 · 04:18 UTC#12
Well what part do you not understand?
Posted Nov 19, 2010 · 11:36 UTC#13
I guess that you just threw me a curveball talking about amp connections, because I thought that was standard practice.
So to clarify:
1.) rem turn on goes to amps per a standard installation
2.) mute wire goes to my external device
3.) new wire installed next to mute wire goes to chassis ground.
Is that correct?
Also, since you seem quite knowledgable, do I really need to hook up the VSS? If I don't, what will I lose?
Thanks for your help
Posted Nov 19, 2010 · 13:14 UTC#14
What is rern and yes? And yes, connect the VSS if you want total GPS accuracy. And re-read what I suggested. Don't try to make sense of it, just do it.
Posted Nov 24, 2010 · 19:27 UTC#15
instead opf moving the mute wire with the 920's because of how difficult it can be to remove it, i have been inserting just a small piece of 18 awg wire into the empty pin and using a little glue to hold the wire in there
