X920BT Rear view camera questions
By karlito · Nov 21, 2010in Problems/Troubleshooting💬 5 posts👁️ 1,506 views
Posted Nov 21, 2010 · 19:52 UTC#1
Is there a thread somewhere that shows the proper way to install rear view camera. Obviously im a newb...lol
Edited Nov 21, 2010 by karlito
Posted Nov 22, 2010 · 16:44 UTC#2
All the X920BT needs is for you to connect the video RCA plug from the camera. The camera itself probably needs two other connections, one is ground and the other 12v acc which you connect to the red wire in your harness.
Posted Nov 30, 2010 · 14:50 UTC#3
yea the install instructions would be with the camera you buy(hopefully), but most are as simple as hooking up two wires (power and ground)and then connecting the video out RCA in to the right connector on the AVIC (brown)
you will also need to connect the reverse wire from the avic to the reverse wire for the car if this wasn't done at the original time of install (most people dont if they are not installing a camera at the same time)
Posted Nov 30, 2010 · 20:11 UTC#4
This is exactly what happened....Thanks for the reply bro.
Posted Dec 01, 2010 · 14:37 UTC#5
no problem
