I just installed a X920BT in my 2005 Ford F-350. Unfortunately I didn't take any pictures, here is my advice whendoing this install.. The whole install took 2 days. I am sure you could do it faster, but I prefered to take my time. The first day was spent wiring the harness. I used 2 Metra aftermarket radio harnesses. Make sure it is a 24 pin connector. I have heard some bad things about Metra so I verified each wire color. You will need 2 of these connectors because you will need to cannibalize 3 of the smaller pins off of the 2nd connector to do a clean install.
Here is the wiring setup you need to do:
Aftermarket Stock Harness
Yellow Green/Purple 12V constant
(right) Red Pink 12V ignition
(left) Red Black Ground
Black Black/light Green Ground
Orange/White Blue/Red 12V illumination
(left) Blue Blue/Red steering wheel remote
(right) Blue Grey/ Black vss lead
Front Speakers
White/Black Blue/White left neg.
Grey/ Black Green/Orange right neg.
White Orange/light Green left pos.
Grey White/light Green right pos.
Rear Speakers
Green/Black Tan/Yellow left neg.
Purple/Black Brown/Pink right neg.
Green Grey/light Blue left pos.
Purple Orange/Red right pos.
Some notes to consider, the after market harness does not have pins for steering wheel remote, or Vss lead. You will have to take the 2nd harness apart to use the leads. I used the blue wire & inserted it into pin 18 spot for steering wheel remote, removed the blue wire off the 1st harness and re-installed it into pin 14 spot for VSS lead.
I also inserted a 2nd red wire into pin 15 spot for a 2nd 12v ignition source for either backup camera or XM module. If you look at the back of your stock harness it will all make sense.
To remove the pins you need to push the 2 red tsbs on the back of the connector forward. Use a scribe and pull the internal red piece completely out. You will use a scribe and hod up the locking tab for the pin while pulling the pin out of the connector. Once you have all the pins where you need them reinsert the red plastic piece.
When you splice the aftermarket harness to your radio harness, use only quality aircraft/ electronics grade splices, not automotive. this makes a big difference, I see alot of people with connection/ loose ground problems.. Don't skimp!!!!!!
Once all the connections are finished I zip tied and wrapped all the wires into a nice tight, neat bundle.
I spliced the Pac remote module into the harness, power to the 12v ignition, ground to ground, and white wire to right side blue wire (pin 18).
To hook up the reverse sense wire, I spliced off of the Pink/Black wire that can be found going from the white connector on the bottom of the steering column going to the back of the fuse box.
Hope this helps someone, if you have any questions, just post and I'll repley back promptly..
Odie
