X920BT issue with Front Rear Fade function
By Giskarded · Nov 29, 2010in Problems/Troubleshooting💬 4 posts👁️ 755 views
Posted Nov 29, 2010 · 21:03 UTC#1
I have the X920BT installed with the bypass done on a 05 4Runner with JBL.
The system works fine for the most part. Only issue I'm facing is when I use the Front or Rear fade and move the sound back.
Eg..
If is is set to Rear, the sound actually moves to the Front speakers and also continues on the rear speakers for a few seconds.... ever randomly
If it is set to Rear left or rear right the sound will move to Front left or Front right respectively while continuing to play on rear left or rear right..
Anyone run into this issue? It happens randomly every 15-20seconds.
Edited Nov 29, 2010 by Giskarded
Posted Nov 30, 2010 · 14:34 UTC#2
are you using a integration module, like a metra or scosche part? not just a basic wire harness but one with a little black box inline (the box doesn't have to be black)
if so most of them are junk, and have a high either failure rate, or a high incompatibility rate, you can try a different module to see if it fixes the problem(either a new mod of the same model to replace the defective one or a different model compleatly to see if it is more compatible).
Posted Dec 01, 2010 · 16:57 UTC#3
Yeah it has a module provided to interface with the Toyota JBL system called PAC TATO.
That was the one recommended by most folks.
I'll ask some folks on the T4R.org forums incase they've run into this issue.
Posted Dec 02, 2010 · 22:15 UTC#4
well normally i would reccomend the metra axxess module instead but ive had just about the same luck with that one
