Ok I picked up my unit used for a pretty good price... Checked it out radio works and GPS worked so I was pretty satisfied.. Hooked it all up in my truck and tried out the DVD, well "nonreadable disc" pops up.. Well I already pretty much knew that meant.. There is something wrong with my player.. Tried to clean that didn't work... So now I gotta look around for another DVD player so I can do the swap or take it to pioneer and see if they will cover it under warrenty and if not then see how much they will charge me for the DVD player and work... I already know how to replace the DVD player it's really easy.. Problem is I don't know the cost of the DVD player replacement.. If I can get it at a decent price (ebay or pioneer or here) then the deck is still worth it considering what I paid.. If it is alot more then well it will piss me off cause then it won't be worth it... So hopefully I get a decent deal.. I can deal without the CD's anyhow.. I will listen to my XM... Anyone got a DVD drive for sale??
One thing is the GPS supose to give me a reading of the KM while I am driving even if the VSS isn't hooked up??? I don't recall seeing it when I was going for a quick drive around the block... GPS antenna is under my dash not installed on the roof...
Now for the install questions hopefully I get some Silverado owners in here.. Specfically my general year model of 2005 non bose....
I assume the VSS hookup will be taken from the cluster (shouldn't this be on the wiring harness if I have the auto volume on stock deck)???? The illumination (I thought that was on the harness) from the HVAC or Light switch??
Also I have the Metra install kit for my truck.. I heard it was a good dash mounting kit so got it... Now I cut the plastic out from the back from what was posted on here from one member.. But it seems like either A) the metra kit is a bad kit or
More plastic back there is forcing the back of the deck on a downward slope because the front of the deck JUST clears the seperator between HVAC and Radio. When it opens you can hear it grazed a little bit of the plastic.. It needs to be center a little more inside the dash opening..So anyone else have a problem with the Metra kits or the Silverado plastics?
On a side note.. My shifter in the truck seems to have been in the way of the side of my screen.. Freeplay in the gear shifter.. So I just push it with my hand hard and bent the handle a little bit. Seems to have works just was being careful wouldnt wanna snap my gear shifter.. Anyone else had this problem? I don't know why there is that freeplay in mine when it's in park...
Anywaz hope to hear a little input
thanks
