Bluetooth problems following CNSD-100FM update
By ajcamp · Dec 03, 2010in Problems/Troubleshooting💬 4 posts👁️ 1,695 views
Posted Dec 03, 2010 · 14:08 UTC#1
Hi
I have a F900BT, which worked well with my HTC HD2 via bluetooth, however since I update with CNSD-100FM, I am having problems with the unit and my phone, the main one being if I get a incoming call, when its finished the F900 does not disconnect and I have to switch off the SatNav, although the phone disconnects, the unit seems to freeze and mutes the radio and freezes the sat nav.
Any ideas please
Tony in London
Posted Dec 06, 2010 · 17:59 UTC#2
Hi
Any ideas please
Tony in London
ive got the same phone with the same problem any solutions
Posted Jan 07, 2011 · 13:46 UTC#3
You could try deleting the phone connection then re-pairing it. Failing that you could try re-updating the bluetooth software. If that fails try re-flashing the firmware.
Posted Sep 29, 2011 · 01:51 UTC#4
same issue here any solution
