X920BT - Which iPod/iPhone Cable Do I Need?
By ugadawgs311 · Dec 03, 2010in General💬 7 posts👁️ 3,586 views
Posted Dec 03, 2010 · 15:55 UTC#1
I recently purchased a X920BT and am going to be installing it soon. Which iPod cable do I need to connect my iPod and/or iPhone to the unit? I've researched the Pioneer CD-IU50V and think that it is way over priced. I've also read that you can use the regular white cable that Apple supplies with the iPod/iPhone. I know that the Pioneer CD-IU50V is requiered if you want to send videos to your HU, but can I purchase a third party cable that has the iPod connection on one end and the usb and 3.5 mm jack on the other end? I've found some online for a fraction of the price of a Pioneer CD-IU50V and want to make sure that it will work. Thanks for any help!
Edited Dec 03, 2010 by ugadawgs311
Posted Dec 03, 2010 · 18:09 UTC#2
I've heard its hit-or-miss. I am in agreement, the $15 cable on eBay looks very tempting. I did notice that some of the "generic" cables will have 3 or 4 bands on the 1/8" jack. Be sure to get one with the 4 bands, as it supports the video.
Posted Dec 04, 2010 · 02:22 UTC#4
And you cant use the cable that came with your Apple device unless you use another cable through the headphone jack of the device to get audio which means you will need to bother with connecting and unconnecting two cables each time you attempt to use the device instead of just one. To me it seems that if you just dropped 500-800 dollars on a new unit another 50 bucks is nothing to sneeze at.
Posted Dec 04, 2010 · 02:50 UTC#5
When I bought my unit the seller gave me the generic CD-IU50V and it kept coming loose from the itouch, I have sense bought the Pioneer unit CD-IU50V and it works great...
Buy Pioneer's cable...
Posted May 06, 2011 · 03:39 UTC#6
so what is this cord for? I thought i could plug my ipod cable into the usb part of this? Is the only way to use the ipod is to get the CD-IU50/V or get the component headphone jack
Posted May 12, 2011 · 01:13 UTC#7
that cable is to plug in to the back of the avic and give you a place to plug in a usb drive with out having to buy anything else, the correct poineer cable will then plug into that cable pictured
as far as the generic cables, sure a few of them work, but one of the biggest problems with AVIC's on this board are due to people using these cheap a$$ cables and then they are defective.
EXTRA THOUGHTS
if you are really that tight for money, then you shouldn't have bought such an expensive radio in the first place!
as far as the 3 or 4 pin cables, not only do you need to get a 4 pin cable for the video to work, but the pinout has to be correct as a lot of cables with the same connector have a different pinout which will not work for this unit. (can effect audio as well)
do yourself a favor, spend the money on the correct parts or trade your avic for a jensen
Edited May 12, 2011 by 1loudls
