120bt question
By mike cartagena · Dec 04, 2010in General💬 2 posts👁️ 949 views
Posted Dec 04, 2010 · 20:31 UTC#1
I have a 120bt and when I put in a mp3 cd and I hear up to the 3rd track. I then turn off the car and when I select to play the mp3 cd it starts off on track 1. I want it to start off on track 3 were I left off. How can this be set? Thanks.
Posted Dec 04, 2010 · 21:06 UTC#2
I haven't played MP3s from CD in a long while, but I think it should remember and continue from the last track. I know it does for SD MP3's.
Are you changing the audio source in between? That might make it start over at the beginning.
Sounds like it is being reset when you turn the unit off. Is the clock correct when you turn on the ignition again? Are your radio presets remembered?
If not, it might be because both power lines are being switched off with the ignition. The yellow wire must be hot always to retain the AVIC's memory.
Edited Dec 05, 2010 by RonS
