Hi Folks,
A few months ago I installed an X920BT in my 2008 Hummer H3 using the GMOS-01 adapter to retain OnStar and chimes.
Everything about the install works great except for the day / night mode on the X920BT. I checked and double checked my connections according to the X920BT and GMOS-01 installation guides and they are correct; however, night mode still does not work.
I have Googled around and searched on this forum and have read that the illumination wire / circuit on the GMOS devices do not work and that the solution is to hard wire in to the illumination wire of your vehicle. The problem with the H3 is that the illumination wire comes over the CAN bus and is not a regular 12v signal wire.
I figured I could just tap into the dimmer wire going to my HVAC controls (which is a 12v wire) to achieve the same effect as the illumination wire, but I read somewhere on this forum that it could potentially brick my X920BT if the dimmer switch is used.
Is it safe for me to use the dimmer circuit on the H3 to get the headunit to switch from day to night mode? If not, is there another alternative for me?
Thanks.
