AVH-P5200BT Won't turn on after 1st installation
By Virzn · Dec 10, 2010in Pioneer AVH Series💬 5 posts👁️ 9,719 views
Posted Dec 10, 2010 · 20:13 UTC#1
Hi,
I connected all wires for the P5200BT according to the manual (12V+,Gnd.,ACC,Light,Remote,Brake) but the HU doesn't turn on. I also pushed the Reset button several times but the unit is just dead.
So I disconnected everything again and used only the Yellow wire to the cars constant 12V+ / Black to the Ground wire of my car and Red to the ACC. Still dead, no noise, nothing. I measured the voltage at the pins from the unit and all got power as supposted to be. It also doesn't matter when I interconnect the ACC to the constant 12V+.
So I figured the HU must be bad and returned it to the dealer and bought a new one that arrived today. So I made a quick test and connected it only with the 12V+, Gnd. and ACC and guess what - it's also dead :?:
Guys, do you have any idea what's the issue??? Do I do something wrong? I mean one unit can be bad but two in sequence?!
Please Help!!!
Cheers
Virzn
Posted Dec 11, 2010 · 02:42 UTC#2
Plug in the tuner. It will not work with out that.
Posted Dec 11, 2010 · 16:33 UTC#3
Here is his wife and I want to say TTTHHHAAANNNKKKSSS!!!!!! He was crazy for a week and sure I couldn't help ;-) Now it work perfectly and I have my lucky Hubie back! Merry X-Mas
Posted Jan 23, 2011 · 18:34 UTC#4
Created a AVIC411 account just to say THANKS!!!! I tested everything before I ziptied all my cables and made it look neat and the unit worked. Right after I cleaned it all up and was about the slide the head unit in, no power :( Tore apart everything, tested voltages, continuity, even used a power supply to power the unit. Nothing... then read this and voila, it turns on again. 5 hours wasted so far, now to clean it all up again. At least I was able to save wasting another day. Thanks so much. I really mean it.
Posted Nov 28, 2016 · 02:22 UTC#5
I'm having the same trouble. When you say tuner what do you mean? Any help greatly appreciated!
