Pinoeer AVIC-D3 Static noise when any button pressed (Bose factory amp installed pathfinder)
By Rush Mayhem IV · Dec 12, 2010in Problems/Troubleshooting💬 6 posts👁️ 2,497 views
Posted Dec 12, 2010 · 17:01 UTC#1
Hello all!
I have been using this site for help a lot (thanks!) but decided to finally register. I have recently purchased a 2005 Nissan Pathfinder and I am having this issue.
When I installed my Pioneer D3 with the factory bose amp using the nissan harness and the PAC SWI for the steering controls I am getting a static noise faintly in the background of the music, but when any button / key / track / menu is hit on the head unit OR steering wheel I receive a static noise that last for about a second. I have done my research and a lot of users say its a sound file within the head unit and it cannot be fixed. I think the factory bose amp is causing this so I am curious if the PAC ROEM-NIS2 will fix this? My ground wire is about 4" long and grounded to the chassis of the double din frame on the car. The head unit is grounded to the frame as well with factory supplied screws. I am sure this is not a grounding issue, but any help is appreciated.
Thank guys!
Posted Dec 13, 2010 · 04:15 UTC#2
Just a shot in the dark... try turning all beep and NAV voices off. I notice a similar issue when the voice is on but all the way down. With beep and voice off the unit should have no reason interupt your music. This is just a S.W.A.G. so let me know if it works for you.
Posted Dec 13, 2010 · 16:23 UTC#3
It's still there just extremely faint. I can live with it but the static when volume all the way up bothers me. Maybe I need that converter for Bose to Pioneer (PAC).
Posted Dec 22, 2010 · 07:30 UTC#4
static still coming. ugh... Its not a static that gets louder as I accelerate, just a constant steady static especially at higer volumes. any ideas?
Posted Dec 22, 2010 · 08:03 UTC#5
Sounds like a mismatch in gain between the head unit and amp. I cannot troubleshoot well unless I have the vehicle. Hook a portable or bookshelf speaker to one of the speaker outputs of the D3 If no static, the D3 is not the problem. If not using the OEM Bose interface converter then try it. Newer factory systems especially Bose are known for nonstandard wiring and definitly not plug and play. Sometimes these will correct ground loops and other problems encountered when using an aftermarket head unit. They make those due to the demand to solve a problem. If you are barely turning up the volume on the D3 (at 5-10 for example) and the factory system is max volume then you have a gain mismatch. The interface unit may solve this problem as well. I have also solved these problems with units like audio control's line driver but sometimes the wiring for these can get tricky for a novice.
Edited Dec 30, 2010 by smitty2
Posted Dec 22, 2010 · 08:13 UTC#6
That is what i am going to try next. My head unit is at -4 and still LOUD on 10! Ill hit you up as soon as I install the PAC ROEM-NIS2
