F700bt troubles!!!
By altima_f700 · Dec 13, 2010in Problems/Troubleshooting💬 4 posts👁️ 1,393 views
Posted Dec 13, 2010 · 08:35 UTC#1
My f700 is giving me all types of problems. I tried loading 2.008 on there, it loaded up and said 100% then whn it restarted itself, it didnt move off the splash screen. Finally it did now im not able to make any audio selections. I can select destination or contacts from the main menu but not AV. Even under the setting menu I cant select "AV setting" or "AV source". Also when i looked under service info screen the map version said none but it show 2.008 as loaded on there. Are there files missing? If so how can i restore them?
Posted Dec 14, 2010 · 13:23 UTC#2
Did you previously have a software bypass? you might need to redo it,
You might also want to try and reload the OS that you backed up before upgrading.
Edited Dec 14, 2010 by dianebrat
Posted Dec 14, 2010 · 18:45 UTC#3
I didnt back up the OS the unit was already acting up whn i got it, so i wasnt able to. Someone told me the update would correct the prob. How can i get the original factory settings and files back on there?
Posted Dec 16, 2010 · 03:52 UTC#4
I would look on the forums here for either a backup, or a full set of files.
And as I said, if you did a software bypass before, it's gone now, just do the smart thing and do the hardware bypass, it's quick, simple, and reliable.
