can't deactivate password
By mike cartagena · Dec 15, 2010in Problems/Troubleshooting💬 5 posts👁️ 1,109 views
Posted Dec 15, 2010 · 22:42 UTC#1
I can't deactivate the password. I know you have to touch section 1, then 2, and hold section 3 but it is not working. Is there a trick that I don't know about?
Posted Dec 16, 2010 · 01:51 UTC#2
Nope.
Posted Jan 02, 2011 · 16:33 UTC#3
Keep trying. If your screen calibration is off it can be tough. Had the same issue. Eventually I got it just right.
Posted Jan 08, 2011 · 01:14 UTC#4
HOW DO I RESET THE BT PIN ON MY Z2. SO I CAN PAIR MY NEW PHONE
Posted Jan 09, 2011 · 13:55 UTC#5
You would probably have had an answer by now if you had posted this in the Z1/Z2/Z3 sub-forum. The Z1x0-BT series has built-in BT. The hardware and software are completely different.
On this unit, BT is an optional add-on. While I found an online pdf manual for the Z2, I could not find any mention of how to use or configure the BT. So you need a Z2 experienced person in the other forum.
Edited Jan 09, 2011 by RonS
